Cat removal - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-24-2011, 11:37 PM
I can't say anything about the domestic cats. I have a Nissan 370Z that installing a high flow cat or ,like I did, test pipes nets you an extra 10-15hp to the wheels. It is about the same gains as installing a new cat back exhaust. Maybe Nissan just uses horrible flowing cars. My friend has knocked the cats out of 2 of his Titans and they both had noticable gains. I can't say what the actual figures were but we aren't emission tested in OK.
There are lots of diesels that run around here and lots have no cats. I know that the newer ones have problems if run with out cats but I don't know years. If it were mine I would find out when it got to be a nessesity. If yours is safe (I think it is) get some test pipes to replace your cats it you can. That way if you have a problem you can go back to them. My test pipes were $100 as aposed to 300+ for HFC's.
  #17 (permalink)
Old 10-25-2011, 07:24 AM
......Not to mention that #1 You will probably never notice the miniscule increase in performance and #2 The federal fine for removing them(should you get caught in a smog check) is somewhere over $2000. Is it worth it?
SBC oil pan removal? v8hed Engine 11 07-08-2008 10:02 PM
Oil pan removal super_silent Engine 8 12-11-2007 11:02 AM
Trim Clip Removal, and backseat removal? ROBINGOODTIME Body - Exterior 2 10-09-2006 08:15 PM
oil pan removal F J Kitto Engine 1 10-14-2003 05:56 AM
help on ls1 removal madman Engine 4 10-09-2002 03:12 PM
