Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cat size suggestion?
Old 02-09-2013, 02:09 PM
TMF Lindbeck TMF Lindbeck is offline
Thinking about this I'm trying to visualize all this stuffed under your truck. If full leingth headers are used and then bolted to the collectors cats, this would put you roughly at the tranny crossmember. I would go out and take some measurements and see if you'll be able to have room for everything.
With regards to cats and hi-po engines the similarity of a gen I,II sbc and a dry sump LS7 end shortly after discussing 16 pushrods and 8 pistons
