Cat size suggestion?
I'm about to pick up a pair of cats to go with some long tube headers for my truck. I understand the cats need to be as close to the heat source as possible, so I'm going to bolt them right at the collector.
Question about size though; I'm going 2.5" dia. for the mufflers and exhaust bu t my collectors are 3". Should I go 3" cats and reduce to 2.5" after? Does it matter? Engine is a 5.7 stocker now, but have plans for a 383 stroker down the road. Thanks |
thanks - I was thinking of 2.5" as I thought 3" might be overkill for my application.
I must run cats to be compliant I'm afraid |
3 inch cats,x or h pipe then exhaust,Ive never seen a reduced system ever make more power,but it is cheaper,
put flanges on both sides of the cats,in case they need to come out and be replaced with straight pipes on occasion? |
To the OP, for a 350 or 383 you're not going to see a huge difference between 3" or 2.5" exhaust off the cats as long as it's quality mandrel-bent exhaust. There's many much bigger and meaner engines out there making due with a dual 2.5" system. |
Thinking about this I'm trying to visualize all this stuffed under your truck. If full leingth headers are used and then bolted to the collectors cats, this would put you roughly at the tranny crossmember. I would go out and take some measurements and see if you'll be able to have room for everything.
With regards to cats and hi-po engines the similarity of a gen I,II sbc and a dry sump LS7 end shortly after discussing 16 pushrods and 8 pistons |
Excellent - thanks guys
| s10 with gutted cat, bad mpgs.. CEL on, Limp home mode from downstream cat? | Dirty Biker | Engine | 6 | 09-04-2012 05:56 AM |
| need suggestion | chevy383 | Engine | 3 | 07-10-2007 12:44 PM |
| suggestion | budynabuick | Hotrodders Site Suggestions and Help | 1 | 08-24-2006 09:44 PM |
| Wire size suggestion. | CdnSoldier | Body - Exterior | 12 | 06-12-2005 02:19 PM |
| Where's the cat??? | wld bil | Hotrodders' Lounge | 12 | 06-23-2004 09:14 PM |
