Cat Wiskers?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2005, 11:45 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Cat Wiskers??
I'm getting ready to put my windows and power units in and I need the bottom seal for the glass. I was told to just use cat wiskers for it and it should be fine. Well I didn't bother to ask what cat wiskers are. Ok I know I should have but..
Anyway I found this and need to ask if this is what I'm looking for
http://hotrodders.com/gallery/showph...cat/500/page/1
I'd ask the guy that told me but he just left till after New Years.
Thanks
David
Old 12-17-2005, 11:53 AM
That is the inner "belt line" seal on a movable window. The outer one could be the same or a rubber "scraper", depending on the car.
What kind of car is this that you are working on? Most of these parts can be bought that fit right on a car,you shouldn't have to "create" anything.
Old 12-17-2005, 01:28 PM
Bluepen's Avatar
Just a firefighter
Wiki Edits: 2
Thanks Brian
I'm woking on my '46 Chevy Panel and I can get the original seal for the windows but the old windows have the metal frame and I'm going frame less on the new ones so I'm not real sure they will work.
David
Old 12-17-2005, 05:25 PM
The original style will work in your application I would assume. Just look at the one on the original frames and figure it out.
What are you doing where the frames use to be? Isn't there a gap were you will see the window channel? I would think, if the frames are anything like the AD, the best way would be to DETAIL the frames so they fit flawlessly.
THE TOPIC helrazr3 Off-Topic 342 05-21-2008 04:49 PM
How much power does a cat really rob? CCR Engine 20 09-16-2004 09:27 PM
CAT stuff camino75080 Engine 5 08-14-2004 08:09 PM
plugs fouling, cat worries, and more - help? joe99 Engine 9 01-23-2004 07:16 PM
CAT Performance Part????? juveteach Engine 18 06-02-2003 11:10 AM
