catalytic converter ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2007, 05:43 PM
65 c10, 283 tbi, 700r4, pb, ps
I have a 283 tbi with just glasspack's on the exhaust, do i have to have a catalytic converter for the o2 sencer to to work right?
Old 02-18-2007, 05:54 PM
DeathRattle's Avatar
Some Punk Kid
Depends on factory specs. Some vehicles had sensors before the cat and some have them after and even some with both. If it came equipped with a sensor before the cat you will be okay without a cat.
Old 02-18-2007, 08:20 PM
RippinRon's Avatar
You must have to O2 sensor for it to work correctly you do not need a cat. The O2 sensor works best being as close to the collector as possible because they require heat before they work.
Old 02-18-2007, 08:25 PM
Thank's that's what i thought. I got it right under the collecter.
1991 olds catalytic converter fumplet Engine 1 01-03-2007 07:42 PM
catalytic converter paulray Engine 6 03-03-2005 05:29 PM
Catalytic Converter Questions ChrisMiddleron Engine 2 02-15-2004 06:30 PM
1986 Catalytic converter with 155,000 on it catscan4free Engine 1 02-07-2004 05:51 PM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 04:43 PM
