catalytic converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2005, 07:18 PM
catalytic converter
Does anyone know if a catalytic converter is needed for back pressure on a 94 dodge ram with a 390 or can I just cut it off.
thanks.
Old 03-02-2005, 07:44 PM
spinn's Avatar
does it have a o2 sensor in front and behind?
Old 03-02-2005, 10:05 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
360.
Do you have to pass and emissions test in your area?
Old 03-03-2005, 03:27 AM
rick458's Avatar
Wookie
A free flowing Cat wont cost you any back pressure, and may well add some wanted resonnance
Old 03-03-2005, 11:36 AM
Siggy_Freud's Avatar
A well functioning, non-clogged catalytic converter will cost you nothing more than 3-4. A "performance" one will cost you less than that. In many places the law requires you have it. Do you really want to be caught with your pants down over 1 or 2 ponies?
Old 03-03-2005, 05:50 PM
catalytic converter
thanks for all responses, the 02 is above the cat. I'm in an emission free state
and was leaning more towards engine performance and the benjamins than
the ponies,and have no problem being caught with my pant's down.
thanks.
Old 03-03-2005, 06:29 PM
spinn's Avatar
well then i suggest tring out a test pipe. look on ebay. save everything cause its a bolt on right in place of your cat. i put one on my truck a while back. had to use the great blue wrench to heat up the threads holding my cat toghether.
if you had a o2 behind you would need a dumbmy sensor. i cant spell for shi....
large catalytic converter? 87442lover Engine 1 04-24-2004 08:09 PM
Catalytic Converter Questions ChrisMiddleron Engine 2 02-15-2004 07:30 PM
1986 Catalytic converter with 155,000 on it catscan4free Engine 1 02-07-2004 06:51 PM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 05:43 PM
Catalytic Converter Problems rehjr0219 Engine 5 02-22-2003 07:01 PM
