catalytic converter for straight 6 79 Ford pick-up - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2008, 09:40 PM
Gladis's Avatar
Any brand of high flow cat particularly better then the other?
Old 01-18-2008, 12:16 AM
Look at the redicusouly small ones that dynomax IIRC has out now there only like 4inches in diameter and 6 inches long
Shane
Old 01-18-2008, 02:58 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Are you sure this has a Cat...?? I am not sure when the change came in but I believe it was after 79 on the pickups..
Sam
Old 01-18-2008, 09:15 AM
I was thinking that 79 was the first year for cats,but I wasnt around then so I'm not sure..
Shane
Old 01-18-2008, 10:38 AM
BlownBigBlock447's Avatar
Check out Magnaflow's, we've had good luck with those. In regards to the ones mentioned that are only 6 inches long, that almost sounds like a flexjoint.
Old 01-18-2008, 05:44 PM
They had them in Hot Rod or Car Craft, on the LS Engine that they built, a pair of them cost about 6hp vs no cats.
Shane
chop 1932 ford pick up wizard1932 Body - Exterior 3 05-18-2009 09:28 PM
Catalytic Converter Questions ChrisMiddleron Engine 2 02-15-2004 07:30 PM
FRAME DEMINSION FOR 40 FORD PICK UP 32racer Suspension - Brakes - Steering 4 10-29-2002 06:09 AM
1950 F-1 ford pick up worth bullheimer Hotrodders' Lounge 7 08-29-2002 07:17 AM
2001 ford pick up wont start right Clinton Hotrodders' Lounge 3 07-10-2002 05:25 PM
