Catastrophic oil pressure loss - SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 07:16 PM
I had the Cutlass out yesterday for a quick spin. At startup I saw 60+ psi on the oil pressure gauge. After a few miles I heard a terrible knock, saw the temp gauge climbing, about 10 psi on the oil pressure gauge. I tried to nurse it home the final mile, but the engine puked and died. I hoofed it home and towed it back with the truck. Once I got it home I spun the oil pump with the priming tool and saw 60+ psi again. The engine had cooled by this time. I put it back together and started it enough to move it back into the garage. So, it does still run.
I know I'm looking at a complete teardown and rebuild here. But what kind of things should I be looking for? What would cause a loss of pressure as the oil warms up? What tools should I be getting to complete this? I've got the basic hand tools and know I will need a few more like a ring compressor, etc.
I'm keeping a positive outlook on this and figuring this will be a good learning experience for me.
thanks
stu...
Old 08-24-2008, 07:41 PM
thanks
stu...
My suspicions go to crank bearings. Things that go knock with a loss of oil pressure that comes back when cold, are usually a bearing going but not gone.
Climbing temp seems related to cooling system or really off timing. You may be looking at more than one problem, they could be related in terms of cause and effect.
Bogie
Bogie
Old 08-24-2008, 08:09 PM
I am a big believer in using lights and beepers with the gauges.
You might miss a fluctuating gauge, but when red lights come on and beepers start sounding,,,, that is hard to ignore.
Saved me one engine several years ago.
Radio Shack beeper $ 5, light sending unit... $ 8 ?
Old 08-24-2008, 08:31 PM
The car has idled in the garage for 10-20 minutes at a time, so I'm confident the cooling system and timing are ok. I was attributing the rising temperature to the lack of oil circulation. My experience has been that oil does a surprising amount of cooling.
I'll be pulling the engine later this week and will have a chance to check things a little closer.
Old 08-24-2008, 08:59 PM
DoubleVision's Avatar
3 jobs of oil. Clean, Cool, and lubricate.
Old 08-24-2008, 10:32 PM
I had a car that would lose oil pressurer every so often. It turned out to be a bad oil filter. check to see if you have a pressure valve in your filter. if not i would look at the mains.
Old 08-25-2008, 11:03 AM
Hopefully louder than the stereo. I ended up with a 289 powered 73 Ford Courier because the 4 cylinder lost a rubber plug off the back of the head. While that happened I was boppin' down the freeway listening to the Stones at a 120 db. by the time I saw the red light the rods and crank were toast.
Checked out the cost of replacing the motor and exclaimed to the guy at the parts counter, "I CAN PUT A V8 IN IT FOR THAT!!!!!!!" and so I did. Well at least the "V8" part happened, for the "that" part it took "that" and quite a bit more denero.
Bogie
oil pressure complete loss Jack Dore Engine 11 07-17-2008 09:56 AM
78' SBC oil pressure gauge hook up spot on block 85-monte Engine 6 05-12-2008 12:12 AM
What is normal oil pressure on a SBC JMEDLEY001 Engine 22 12-31-2006 05:42 AM
oil pressure switch Blob Engine 7 12-02-2005 01:34 PM
