Cause of Whining Differential? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2012, 02:12 PM
I'm planning on rebuilding my differential before refitting it to the chassis
From what I've read, these differentials have a tendency to whine
Since my car was a non-runner when I got it I have no idea if my diff has any problems.....but I'd rather rebuild it now, than facing the possibility of removing it from the car once it's back on the road
From speaking to other owners I've been told the whining (when present) is caused by the hardening on the crown wheel becoming worn through
The noise will be loudest on acceleration either disappear entirely or become very low on overrun/deceleration
The pinion bearings can also be a problem, but the noise is from the centre of the car (not on one side) and is very short term, i.e. the bearing collapses, the oil leaks out and the differential seizes
So..........
Does that sound right that the crown wheel hardening would cause the whining?
Can I do anything to check for this before reinstallation?
I'm planning on fitting new shims, bearings, and gaskets, but I'm a little worried about the crown wheel
As ever, your insight is most appreciated
Thanks, and Merry Christmas to you all
Old 12-25-2012, 02:34 PM
big gear head's Avatar
High Performance Rear Ends
What kind of car is it? What differential is in it?
Most of the time the bearings will cause the noise. It can be a pinion or differential bearing. Maybe cars in England have problems with the heat treatment of the gears, or maybe the metal is bad, but the gears are usually not the cause here. If a gear is bad it usually shows up as soon as the gears are installed.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-10-2013)
Old 12-25-2012, 02:56 PM
Car is '71 Triumph GT6
Differential is stock 3.27:1 Item
Here's the exploded diagram for it.......
Rear Axle Centre Details : Axles, Suspension, Drive Shafts and Wheels : Triumph GT6 MkIII Spare Parts Catalogue - Canley Classics
Should I just look for unusual wear in the gears, or can they be heat treated again?
I've got the workshop manual, which I believe shows the dimensions and clearances
As these measurements are for new units, should they still be relied on, or should there be some 'give' in them?
Old 12-25-2012, 07:18 PM
I don't know about the gears, but I would check the bearings first. If it is the gears they can not be fixed. Plan to replace them.
Old 12-25-2012, 09:03 PM
Cool
So, as the condition is currently unknown I think I'll do a rebuild with new seals, bearings and shims and see how we go
Whining Alternator? locomark Engine 7 06-19-2007 12:50 PM
whining in reverse? tinman386 Transmission - Rearend 10 11-06-2006 07:29 AM
I stopped by and everybody’s whining. rs Hotrodders' Lounge 42 11-27-2004 10:57 PM
Quit 'yer whining Weimer Hotrodders' Lounge 1 06-06-2004 11:22 AM
distributor whining Mr.E Engine 2 01-11-2003 05:15 AM
