causes for high volt meter reading +16 ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2008, 10:28 AM
Installed a 1994 LT-1 from a Z/28 in my coupe. Upon startup the volt meter pegged at 16 + volts ! What are the causes for this ?
The car has a new Optima battery
New Shark in dash volt meter gauge ( made by Dolphin )
The starter and Alt. were taken to Advanced Auto and checked out O.K
The wiring is a new Ron Francis setup for the LT-1
Besides, the high volt meter reading the stock dual electric fans work intermitely. This may,or may not be the cause for the high volt meter reading ? Any and all help would greatly be appreciated
Thanks
Old 05-11-2008, 01:12 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Do you have a multi-meter? If so check the voltage at the battery terminals while it's running...if it matches your gauge the voltage regulator is probably bad
Old 05-11-2008, 03:16 PM
Holder350's Avatar
Auto Parts Professional
Are we talking a true VOLT meter or a Ampmeter?
theres 2 diffrent ways of wiring each.
An Ampmeter wires from the positive on the bat to the positive on the alt.
And a VOLT meter wires + and -
Last edited by Holder350; 05-11-2008 at 03:18 PM. Reason: used HTML insted of forum tools
Old 05-11-2008, 04:13 PM
Thanks, for the suggestions.
I will check the voltage readings at the battery.
I have a in dash volt meter..not a amp gauge.
I will double check the volt meter wiring also.
causes for high volt meter reading +16 ! wheel-7 Electrical 1 05-11-2008 05:42 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
16 volt systems cojohnso Electrical 1 08-20-2004 03:13 PM
