Does anyone know what type/size fitting was used on the Chevy Cavalier power steering rack fluid lines? Not the pump connections, but the hard lines for the assist cylinder. I purchased a rebuilt rack to install on my 1948 Plymouth, but the supplied hard line at the passenger end of the rack needs to be modified a bit in order to fit. The bend in the line won't allow the rack to be positioned correctly. The bend hits the underside of the frame, so I need to either replace the line, or find a fitting that will provide clearance. I was hesitant to disassemble the existing fitting before I asked the question. A search failed to discover any clues.
They are probably the Captive O ring design. Most likely same as the pump end of it.
As far as making a modification ,you might use a 90 degree elbow/compression fitting along with the O ring fitting end to make a tight corner fitting, although it wont be pretty.
Getting a tight bend on any tubing will be a tough thing to do.
You could take a walk at the U pull it yard and get a better Idea what is easily available.
you may find a hose that is already made with a good 90 degree bend made into it.
This one has an O ring style and has a real tight 90 on the one end.
I think if you look around at an Edelman catalog or the dorman catalog you can find one that can be easily made to fit and look presentable on your build
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
