Cavalier R&P with Ford pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2010, 05:38 PM
I have a potential customer who has installed a Cavalier rack and pinion on his 50 Ford. He's using a Ford pump and claims that it makes quite a growl after it warms up. He believes it has been bled twelve ways to sundown
I'm wondering if the operating pressures are different between the pump and rack? Any ideas?
Thanks!
David
Old 05-26-2010, 07:29 PM
BOBCRMAN@aol.com's Avatar
GM uses higher pump operating pressure than FORD.
Old 05-26-2010, 10:00 PM
Do you suppose the rack is not receiving an adequate operating pressure? I'm trying envision what kinda of problems that may cause. I would think it would cause an assist lag or jerkyness. Would it also cause a growling?
David
Old 05-27-2010, 08:02 AM
Overload a pump with a high demand rack or hard steering and you'll get the whine/hiss from the pressure relief valve. Overload a rack with high pressure and it will be too sensitive - no feel in the steering wheel. Too little pressure at the rack and it will be hard to turn but the pump will be happy because it just doesn't know any better. I can't see any combo resulting in a groan unless you're mislabling a whining noise (check valve) as groaning.
Old 05-27-2010, 10:26 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Make sure the return hose to the pump is not restricted. If it is, it will cavitate the pump causing a growling noise (the fluid may be foamy also). If the hose appears ok, but is small, like less than 3/8" diameter, replace it with a larger hose and fittings.
Andy
Old 05-31-2010, 05:27 PM
Thanks for the replies and suggestions. I'll have him bring it by the shop and give it a look see.
David
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Ford fuel pump connections? 1953 Homer Engine 3 02-05-2008 09:18 AM
Chevy Cavalier PS for '49-'51 Ford wem mccarthy Suspension - Brakes - Steering 2 01-25-2007 03:42 PM
electric fuel pump vapor locks on Ford V8 ? junkyard junkie Engine 9 04-03-2006 09:17 AM
where to buy a R&p ford 9 " 62galaxiguy Transmission - Rearend 1 03-14-2005 04:44 PM
