When you go to cutting, cut the top and bottom, then fold the two
metal flaps back inside. that's so the old radio can be put back if ever restored to original. You should have install directions with your CD deck. Shane. |
To power your CD player, use the old live wire from the original radio. You will also need a constant 12 volt sourse to keep proper time on the clock and station presets. Your instructions explain this .
Run all new speaker wires. Get quality speaker wire, not thin junk. You might want to upgrade to an amplifier later. If you don't want to cut the dash, build a little console under the dash to put it in..
Ontario Rodders |
Well i am tight on money and I am painting my dash as soon as the humidity clears up like hopefully tomorrow. It is all that is left to paint. But it is an alpine standard size deck. Shouldnt it be a standard mount?
around it. but yea it should be standard size. |
Try this link they should have the mounting size for the radio you want to install. www.crutchfield.com
if you flow is low, just go down to your nearest car audio place and see if they will measure up the DIN sleeve for you, or even better, lend you one to trace out.unless they are real stingy or hard up for install work, they should be willing to help you out (especially if you are buying your deck from them
