ceacked dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2013, 12:24 PM
ceacked dash
my '69 Cutlass dash has couple small cracks i it . I've tried using the vynl patch stuff , where you mix the colors together till you get the shade you want , this worked fine and leather (vynl) 'grain design' pad over the fresh patch, but never seems to cure . It seemed like it necver really set up , so tried heating it with a shop lite , almost burned it , It looked fine for a short while, then cracked again. Maybe it needs a different method of heating it to cure ???? If so , how do you (I) do it ????thanks P S , it is a padded dash
Old 01-31-2013, 05:47 PM
old thread?? not sure i can help, but i have done the same repair with the same kit and had the same results! that should count for something. I had a couple of "junk" dash pads and decided to experiment. i filled the crack with epoxy and tryed to lay it in as smooth as possible. i sanded and refilled and it started to look good!!!! the texture is the problem. my '66 cutlass has the innie texture and your '69 cutlass may have the outy texture. you can buy rough texture paint in a rattle can and carfully texture the area. i'm thinking you may have to color dye (paint) the whole dash. i've seen this done and it works!
i did the repairs 3 years ago and stored the dash pads in my attic extreme heat and below zerro again tonite and the repairs seem fine!! the repairs look so good that these 2 dash pads look better than the "good" one
PS i also experimented with "super glue" on the little cracks they are still holding also!!
Old 01-31-2013, 06:38 PM
I tried it again, using variuous temppperature on the 'pressing' tool. It's better, not like new.The proper heat, I think, is VERY criticle ! A couple times I had it looking pretty good, then tried alittle more heat, and made a mess. One major problem I had was it was alreay 'painted' over to differnt color, and with too much hear, the dye would separate from the vynl. I'll try it again one of these days.
Old 02-01-2013, 02:27 PM
hawk.. the texture "bubble gum " kits might be the answer for the texture. no one will ever convince me it'll "glue" a crack and it will hold...FAIL
Old 02-01-2013, 04:17 PM
the textured paint sounds like what I need now , just what or where do i look for that ???thanks
Old 02-01-2013, 09:11 PM
wrinkle paint is a rattle can that you should be able to buy at an auto parts store. when you spray it on it looks like its not going to work, goes on kinda smooth. give it time to flash between coats it will give you a fine texture like your vinyl dash.
Old 02-02-2013, 08:08 AM
I'll try it , thanks!!!
Old 02-02-2013, 09:51 AM
DanTwoLakes's Avatar
Wiki Edits: 22
SEM also has a textured product #39853. The can says "reproduces textured finish on automotive bumpers, dashes, fiberglass tops and plastic parts". I think it comes in black and also clear. This would be your best choice for your dash.
Old 02-02-2013, 11:49 AM
Dan, that looks like a better product for this app.!!! i'll look for SEM textura also
57 belair pot mtl dash to metal dash adsmtz Body - Exterior 1 09-03-2012 06:00 AM
dash vinTag on dash newbie2010 Hotrodding Basics 1 07-28-2010 01:15 PM
WANT TO TRADE? LHD 64' Impala dash for RHD 64' Impala Dash garagedoreen Interior 1 11-18-2007 07:55 AM
Old Dash out< New dash for gages. AmericanPackMule Interior 1 12-29-2005 08:29 PM
55 Gmc dash to 55 chevy dash stubbys 55 Interior 4 12-03-2002 09:30 AM
