ceased perkins diesel - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2009, 09:06 PM
i have a perkins diesel engine that i got running. it was ceased from not running for 20 years. i pulled the injectors out and filed the cylinders with diesel, let it sit for a few days and it cranked over after a few tries. it probably got a little bit of water in the cylinders, but not much.
so i got it running really well but when i was running it again tonight (first time in the dark) i saw sparks coming out of the muffler. lots of them.
could this be the piston rings coming apart because of rough cylinder walls or just a rusty muffler. theres about 5 feet of pipe including the muffler.
thanks
Old 10-05-2009, 09:56 PM
old76c10's Avatar
all jacked up on mountain dew
more than likely its just the rust in the pipe and muffler making the sparks.what do you plan to do with it? what size is it? i have a big v8 perkins engine it sounds awesome with straight pipes but its not really a engine you want in a truck good low end torque but thats about it
Old 10-05-2009, 10:08 PM
i dont really know much about the engine other than its old and has 4 cylinders. its probably early 60s. im planing on putting it in my flat bed farm truck but if it decides to blow up then i need to find something else.
do rings spark a lot when there coming apart or do they just spark a little bit. im just trying to figure out whats up before i spend money on it. its going to need an injection pump soon.
thanks
Old 10-06-2009, 05:19 AM
It's not the rings, brand new ones will do this thats why they put spark arresters on deisel generators.If it runs ok now it should be fine.
Old 10-06-2009, 08:40 AM
sbchevfreak's Avatar
Licenced Automotive Technician
Definately not the rings. If there was a ring problem remotelt bad, that diesel wouldn't run. No rings, no compression, no compression, no fire in a diesel engine.
Old 10-06-2009, 09:14 AM
well thats good to hear. i was thinking it wasnt the rings because ive run it for almost 2 hours now and it still starts and runs just fine.
thanks for your help!
Who's the dumber one... a diesel in gasoline accident curtis73 Engine 14 07-23-2009 10:52 AM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Diesel monte......don't hunt me down for writing this Jzarczyn Engine 31 09-05-2006 10:45 PM
stovebolt diesel? jtdiesel Engine 4 08-20-2006 11:12 PM
351 to diesel donnerdog Engine 18 03-15-2006 02:13 PM
