-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   center condsole (http://www.hotrodders.com/forum/center-condsole-212030.html)
tbrown8338 01-08-2012 03:04 PM
center condsole
i have a 1949 chevy pickup and i want to put a condsole in the center for my radio and etc. i have a floor shifter so the condsole will have to go in front of the shifter. have anyone ever used a condsole from another vehicle that worked good. please help!!!!!!!!!!!!!!! give me some pointers
OneMoreTime 01-08-2012 03:15 PM
kind of a tough one. Most guys wind up making something that will work for them could be simple or complex..I have made those from wood and finished them so they were nice and smooth..As well I have made consoles for a work truck that were rough and worked fine to hold a coffee cup and stray tools..
Sam
123pugsy 01-09-2012 05:00 AM
I agree with Sam.
Get the jigsaw, wood, glue and screws out and you'll be on your way.
I find it helps to cut templates from cardboard and tape them all together to see how it will look.
Stick895 01-09-2012 09:49 AM
There's a wealth of info, both on design, builds and materials, at http://www.fiberglassforums.com/
Silentfallen 01-09-2012 10:33 PM
Its a dead link for me. Anyone else.??
123pugsy 01-10-2012 04:51 AM
Works for me fine and looks like a nice site with a ton of info. :thumbup:
Irelands child 01-10-2012 07:55 AM
It might have been down as I see that no new folks can register - possibly hit with a virus which needs a clean up
Looks like a wealth of info there for those who don't mind getting their fingers sticky.
As far as consoles, I fabbed one together for my '31 from 3/8" tubing, put a sheet metal cover, then upholstered it with a premium vinyl. Looks great - except once I got the car done, I found that I had no room for my right knee(I'm 6'4" tall) so am storing it for the "next build"
http://i70.photobucket.com/albums/i8...d/Iterior5.jpg
This was set up for a stereo and a/c controls, as well as the Lokar shifter tho all of the holes hadn't been opened in the fabric in the photo.
Dave W
mknittle 01-17-2012 08:21 AM
Have you tried here?
http://67-72chevytrucks.com/vboard/f...splay.php?f=13
Gaformz 03-03-2012 11:12 AM
Console
Hi, i specialize in fiberglass parts i can tell you how to do a simple one or maybe build you one, If you need help just ask ,my company does nothing but make fiberglass parts and interiors...thanks
pnt4u2 11-01-2012 09:22 PM
Center Console
[B]TBrown, In my 54 F100 I built my center console using plywood sides, covered in carpet to match my floor. I used lexite for the center which I mounted my radio, frame lights switch, switch for my cowel vent and my A/C controls. Lexite, when painted from the back side, looks great from the otherside. I painted the lexite black to match my dash and it came out looking like glass on the outside and I don't worry about scratching the paint. I mounted my console to my B&M floor shifter bracket mounting holes used to mount the original B&M cover.:cool:
sedanbob 11-01-2012 09:33 PM
3 Attachment(s)
I built the dash extension and console for my '33 sedan out of fiberglass. I shaped pink builder's foam to what I wanted, then covered it with aluminum foil (polyester resin eats pink foam). Laid glass mat over the foam in several layers, then pulled the foam out and finished the surface with body filler.
123pugsy 11-02-2012 04:44 AM
This post is useless without pics. :D
Edit: Your pics showed up after I posted. :smash::smash:
Phaeton 11-02-2012 05:52 AM
They may have something that your looking for.
Classic Custom Consoles
purple fifty one 11-02-2012 01:25 PM
console?
maybe the s10/blazer consoles might work for you...
ogre 11-02-2012 05:31 PM
i made mine out of fiberglass
learned everything about fg from fiberglassforums.com
check out my interior build over there
http://i306.photobucket.com/albums/n...0529091519.jpg
http://i306.photobucket.com/albums/n...llowTrk-38.jpg
