kind of a tough one. Most guys wind up making something that will work for them could be simple or complex..I have made those from wood and finished them so they were nice and smooth..As well I have made consoles for a work truck that were rough and worked fine to hold a coffee cup and stray tools..
Sam
I agree with Sam.
Get the jigsaw, wood, glue and screws out and you'll be on your way. I find it helps to cut templates from cardboard and tape them all together to see how it will look. |
There's a wealth of info, both on design, builds and materials, at http://www.fiberglassforums.com/
Its a dead link for me. Anyone else.??
Works for me fine and looks like a nice site with a ton of info. |
It might have been down as I see that no new folks can register - possibly hit with a virus which needs a clean up
Looks like a wealth of info there for those who don't mind getting their fingers sticky. As far as consoles, I fabbed one together for my '31 from 3/8" tubing, put a sheet metal cover, then upholstered it with a premium vinyl. Looks great - except once I got the car done, I found that I had no room for my right knee(I'm 6'4" tall) so am storing it for the "next build" ![]() This was set up for a stereo and a/c controls, as well as the Lokar shifter tho all of the holes hadn't been opened in the fabric in the photo. Dave W |
Console
Hi, i specialize in fiberglass parts i can tell you how to do a simple one or maybe build you one, If you need help just ask ,my company does nothing but make fiberglass parts and interiors...thanks
Center Console
[B]TBrown, In my 54 F100 I built my center console using plywood sides, covered in carpet to match my floor. I used lexite for the center which I mounted my radio, frame lights switch, switch for my cowel vent and my A/C controls. Lexite, when painted from the back side, looks great from the otherside. I painted the lexite black to match my dash and it came out looking like glass on the outside and I don't worry about scratching the paint. I mounted my console to my B&M floor shifter bracket mounting holes used to mount the original B&M cover.
I built the dash extension and console for my '33 sedan out of fiberglass. I shaped pink builder's foam to what I wanted, then covered it with aluminum foil (polyester resin eats pink foam). Laid glass mat over the foam in several layers, then pulled the foam out and finished the surface with body filler.
![]() Edit: Your pics showed up after I posted. ![]()
They may have something that your looking for.
Classic Custom Consoles |
i made mine out of fiberglass
learned everything about fg from fiberglassforums.com check out my interior build over there ![]()
| Recent Interior posts with photos |
| sbc engine mount center to center | gufnstuf | Hotrodding Basics | 2 | 09-14-2011 12:37 PM |
| Looking for a 22 1/2 center to center power rack and pinion | grobb284 | Suspension - Brakes - Steering | 5 | 09-28-2008 06:26 AM |
| Lifter Bore Center To Center Measurement | 345 desoto | Engine | 1 | 08-08-2008 11:48 AM |
| Center-to-Center diamensions of .... | AHotRod | Suspension - Brakes - Steering | 3 | 05-23-2002 09:18 AM |
| Center-to-Center diamensions of .... | AHotRod | Suspension - Brakes - Steering | 0 | 05-19-2002 01:45 PM |
