Center Console - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2002, 11:28 AM
New Member
Question Center Console
What type of bond should i use you mold my shifter cover in my my Camaro Consloe ? The console is plasticwith foam on top of the plastic.
Old 10-28-2002, 02:58 PM
BOBCRMAN@aol.com's Avatar
Post
you have to find out what type of plastic you are dealing with, some you can use 3m super trim adhesive on, some epoxie, some contact glue.depends on the plastic
Old 10-28-2002, 03:11 PM
New Member
Question
could i use a piece of metel and then use bondo to make it level ?
[ October 28, 2002: Message edited by: Custom79Chevy ]</p>
Old 11-04-2002, 08:01 PM
New Member
Post
will that work or not please let me know
Old 11-06-2002, 01:34 PM
New Member
Post
Not to sure exactly what the camaro console looks like around the shifter but it would work fine taking care to get the shape as close as possible using as little filler as poss , once preped and painted should look fine other alternative would be to get the metal as close as you can and take it to the local trim shop and get it matched to the original foam/fabric combo , for something that size it'd cost bugger all to
Cheers
Dale.
