center line rims - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2008, 07:29 PM
center line rims
when running centerline 2 piece rims (i have 15x12) do u have to use tubs? i heard you can silicone the two halfs and i wouldnt have to.any guys gals do this
Old 02-02-2008, 07:41 PM
poncho62's Avatar
Wiki Edits: 5
I would think that there is some sort of sealant in there already........If the wheels were not designed for tubeless tires, I would think that they would not have the bead ridge built in either.
Old 02-03-2008, 07:35 AM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
I run 15X15's and use tubes with the rear tires. I thought it was due to the tires though, not the wheels. The tires specified the use of tubes.
Jason
Old 02-03-2008, 04:35 PM
el pollo's Avatar
It's shady under this tree...
It's the tires only that specify whether to use tubes.
When it comes to tires, tubeless tires have an "interliner" that is molded into the inner cavity of the tire. It's only function is to slow the migration of air molecules through the rubber and escape the tire, causing deflation. When a tube is added to the equation, heat generated from the friction between the tube and interliner will cause the tire to wear at an accelerated rate, and in some cases (usually in hotter climates, or in severe duty scenarios) will cause the tire to blow out.
Tires that are tube-type (usually bias ply or bias belted trailer or OTR tires, as well s some racing slicks) lack the interliner of traditional tires. And although you will see an accelerated wear characteristic due to the heat generation between the tire and tube, blowouts are usually not experienced.
The Centerline rim that you are using uses the silicone seal between the two halves to stop air loss. That seal is also designed to be replaced if ever necessary. It is an older design setup, being new methods eliminate the need for a silicone seal. This seal is not intended to be used as a deciding factor in whether to run a tube or not.
Old 02-03-2008, 06:54 PM
Dugg's Avatar
My compass doesn't point North
Another question on Centerlines.
I recently looked at Centerline auto drag wheels. Cast into the center spacer was; Bias ply tires only.
So, you aren't suppose to use radial tires on Centerline wheels?
Old 02-03-2008, 08:19 PM
center line rims
my tires don't have anything bout being tubelss or not, they are a hoosier dirt tire M90
Old 02-04-2008, 12:23 AM
Hmmm IDK, I know some wheels are supposed to be radial only and some Bias only, I think it has something to do with the engineering behind the wheel.
Shane
Old 02-06-2008, 09:18 AM
el pollo's Avatar
Supposedly it has to do with the density of the aluminum. Cast wheels that use a pour only method will flex more, and are better suited with bias tires, which do not flex in the sidewall nearly as much as a radial. Back in the 90s, American Eagle had issued with their cast wheels with radial tires. Oftentimes the wheels would develope small stress cracks, and cause leaks.
Vacuum-drawn cast wheels are more durable because the cooling is more even. These wheels flex less and are better suited for radial tires. They are also more common as the method is becoming cheaper to use in wheel production. As an example, OE Ford wheels are often stamped with "Radial tire only" on the inside of the wheel.
Forged wheels (which Centerline usually forges their wheels) are dictated on whether they are intended for radial or bias by the thickness of the aluminum.
Centerline likely stamped "bias ply only" because if you had a radial tire mounted onto the wheels, it's more likely that the wheel will bend under load. Also, if you fasten the slick (assuming you use it for drag racing) with sheet metal screws, a radial tire, due to it's flex, may cause the aluminum to tear and may pose a liability issue with Centerline.
looking to find aftermarket or repro center caps for iroc rims ChevyJim Body - Exterior 6 02-02-2006 10:04 PM
brake line update 61bone Suspension - Brakes - Steering 5 07-07-2005 05:42 AM
RPM range on 110 Center line? Drewnashty Engine 7 06-12-2005 11:19 PM
84 bronco front brake line hatebreed Suspension - Brakes - Steering 6 05-20-2005 02:28 PM
gona pick up some new rims montea General Rodding Tech 4 10-16-2004 12:31 PM
