We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 01-28-2006, 06:30 PM
rlb rlb is offline
center section measurement???
i am in the process of designing a frame (full size on paper) i purchased a 9" housing assembly (shorted to 47") with axles. i do not have a center section because i wanted to be sure of my tranny gears before deciding on rear end gear ratio. finally decided on a tremec 5 speed 600 ft lbs #tcet 5008. it showed up yesterday.
my question is, can anyone tell me the length of a strange or currie center section from the face of the housing to the center of the yoke ? i am also interested in the distance of drop from the center of the housing to the center of the yoke. according to the pictures there is quite a bit of drop.
these measurements needs to be as close as possible, they are going to be used to determine how low i can mount the engine/ tranny and still have acceptable driveshaft angle.
thank you for your time, i have had no luck on there web sites or there tech questions. thanks again
anyone have a suggestion on rear end gear ratio for that tranny and 25" diameter tires for a 550hp street runner that would be cool too.
1st= 2.87
2nd=1.89
3rd=1.28
4th=1.00
od= .64
Old 01-30-2006, 07:05 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
68NovaSS's barnstar
Wiki editor
Wiki Edits: 9
Here's my measurements on a Currie 9+ carrier, Daytona pinion support and a Strange U1603/1350 pinion yoke:
From the mounting surface forward to the joint center = 9 3/8""
From the pinion center up to the top of the carrier = 8"
From the left carrier side (passenger side) to the pinion center = 5 1/4"
From the right carrier side to pinion center = 6 3/4"
Larry
Old 01-30-2006, 07:34 PM
rlb rlb is offline
thank you for your time.... i apprechiate it big time
one more step complete
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "center section measurement???"
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Instant Center Location Of 4link BillyShope Suspension - Brakes - Steering 4 08-12-2004 06:27 PM
Pete and Jakes center section? st3gamefarm Hotrodding Basics 1 02-26-2004 05:12 PM
new help section + solutions to sloppy posting Jon Hotrodders' Lounge 5 07-03-2003 01:36 PM
center section yoke zonk Transmission - Rearend 3 02-23-2003 05:46 AM
