Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - center tri carb won't idle...
Old 04-30-2008, 04:28 PM
kbyounger kbyounger is offline
Thanks - perhaps I have not let the car run long enough... to warm up. The vacuum deal, may not have been stated correctly on my part. There is a small vacuum hose leading to a very small canister on the passenger side of the carb, with a lever that connects to the choke plate - thus I thought it was a vacuum operated choke of some type, but I must say, it really seems to have no control over this plate, even though the two are connected. The rod end off the canister is in a slot on the arm of the plate, and just seems to slide in this slot with no real effect on the movement of the plate. Thanks - kip
