Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - center tri carb won't idle...
Old 05-01-2008, 02:39 PM
kbyounger kbyounger is offline
Well, I got the car to run long enough to warm up, and then sprayed carb cleaner around the carb and found no leaks, sprayed up and down along the intake where it sets on the heads and the complete drivers side leaked and most of the passenger side. We did not use sealant on the sides, only the gasket. On the front and rear we used the preformed rubber pieces and sealant. Perhaps the rubber pieces are too high, and may need to just sealant there and on the sides? thanks - kip
