Centerforce flywheel balance - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 06:37 PM
So I am in the process of installing my new 327 build. I had the crank balanced (rotating assembly), but not the clutch and flywheel.
The flywheel is a Centerforce 700107 billet, which is internal balance. It's a ram clutch, can't remember the part number.
My question is should I bother taking the flywheel in to get it balanced or does Centerforce do a good job at making them neutral?
Thanks
Old 05-03-2012, 09:16 PM
New Member
if your engine is internally balanced then the balance is fine. however, your suppost to take a new flywheel to a machine shop. i just bought a flywheel from summit for my 69 chevelle and installed it and the clutch went out. It turned out the flywheel was'nt flat. my machinist said you should always cut a new flywheel to make sure it runs true. mine was so bad he had to cut the backside mounting pad before he could give me a fresh surface cause it was so uneven.
Old 05-04-2012, 09:01 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Thanks
The flywheel and clutch should be submitted to the machine shop when they do a balance. That said, you will *probably* be fine with just the engine balance.
Old 05-04-2012, 10:02 AM
If you're gonna do the flywheel, go ahead and get the pressure plate done also. The biggest problem I have seen with new flywheels is the location of the PP on the flywheel...if its off just a little, the imbalance caused can be very significant.
Chevy 4.3 L Flywheel Balance v123 Transmission - Rearend 2 03-31-2012 09:49 AM
T56 flywheel balance questions Travis24 Transmission - Rearend 0 10-19-2010 11:30 AM
305 Bobweight/Flywheel Balance mnorton Engine 2 02-27-2010 06:38 PM
external balance 454 aluminum flywheel dman16 Engine 0 03-26-2009 11:02 PM
Anyone have an idea...balance flywheel 357f-150 Transmission - Rearend 9 02-14-2005 06:41 PM
