centrifugal force - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 02-03-2009, 02:17 PM
How fast is fast enough?
centrifugal force
I just saw a reference to centrifugal force in a wikipedia article. The man who wrote that should be shot. Its like people saying the world is flat. Centrifugal force does not exist, and even though you cannot see past the horizon, the world is round.
Sorry, just had to rant.
Old 02-03-2009, 02:34 PM
MorrisonLC's Avatar
Yeah, I remember learning that in physics class. It's centripetal acceleration, right? It acts tangential to the path of the object or something? You should get on Wikipedia and change it!
(This thread will probably get moved. . .)
Old 02-03-2009, 02:42 PM
Oh it will be deleted in about 3 minutes probably and there si no centrifugal anything. Its tangential force that most people mislabel, though sometimes its the normal force.
Old 02-03-2009, 02:58 PM
Ring World solved this problem, unless you were on the outer rim.
Bogie
Old 02-03-2009, 03:05 PM
LOL, I just read up on that, looks like a book I may have to check out.
Old 02-03-2009, 03:11 PM
Your welcome, I'm betting on your enjoyment.
Bogie
Old 02-03-2009, 04:17 PM
Jmark's Avatar
Wow, you guys are really out there!! LOL
Old 02-03-2009, 04:46 PM
You have no idea my friend.
Old 02-03-2009, 09:03 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Thanks for making me learn!
As if I did not have enuf to do!
LOL
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 02-04-2009, 06:03 AM
poncho62's Avatar
Wiki Edits: 5
Maybe, you should go edit and correct it.
Ontario Rodders
Old 02-04-2009, 09:39 AM
dinger's Avatar
That's a good idea. Wikepedia is only as reliable and as informative as the person wring the info.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-04-2009, 09:51 AM
poncho62's Avatar
Wiki Edits: 5
And, it gets you a barnstar...................
I would go do it, but would probably get it wrong too.....All I know is, when you spin something fast enough, it flings it away................
Ontario Rodders
Old 02-04-2009, 10:16 AM
MorrisonLC's Avatar
Wiki OK, just look some more
Wikipedia has the physics right. It's under "centripetal force" (-petal not -fugal) and "reactive centrifugal force" CentriFUGAL force is a false concept but they explain that OK.
Old 02-04-2009, 10:41 AM
post a link to the article...
simply spin a object in 0 gravity does induce a "gravity force" at the perimeter...
problem is nobody knows what gravity is!!!
Old 02-04-2009, 11:22 AM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
The way I understand it, most atoms and molecules are attracted to each other.
You can have two planets of the same size but if planet A consists of material that is denser than planet B, planet A will have more gravitational force. More molecules are pulling whatever is on the surface.
That explains why on the shore of the a sea on Earth, we get high tide when the moon is in the sky. The moon's gravitational pull cancels out some of the Earth's pull on everything, but unlike land, the water's fluidity allows it to move around under the influence of the moon.
Locking full centrifugal advance and vacuum question bubbahotep Engine 30 08-12-2008 09:23 AM
intake leak? cope Engine 4 05-08-2008 07:59 PM
Free Body Diagrams BillyShope Suspension - Brakes - Steering 4 04-27-2007 05:40 AM
Ashley Force Speeds To 4.936 Seconds At 315 Mph In Testing Rob Keller Hotrodders' Lounge 5 04-12-2006 08:44 AM
Supercharge it! The replacement for displacement... Roots, Twin Screw, Centrifugal? MadJester Engine 19 12-12-2004 03:20 PM
