Centrifugal supercharged 5.9 dakota makes low boost in high gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2009, 05:27 PM
5.9 dakota vortech S-trim blower 11lb pulley setup. .210/.220 .512 lift cam with 110 LSA. And Mopar RT 2.02 heads.
Car makes full 11psi of boost in 1st and 2nd gear. Shifting into 3rd boost drops to 6ish??? And ideas as to what would cause this?
Thanks
Old 06-30-2009, 09:48 PM
KA67_72's Avatar
Does it start building as RPM goes up in third or does it stay at 6 all the way to redline?
Kevin
Old 06-30-2009, 11:08 PM
Stays at 6ish... full 11 pretty instantly in other gears.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Need some help sorting out tranny ratios and rear end ratios firstgear Transmission - Rearend 3 11-06-2008 08:39 AM
Octane Booster Info SLR_65 Engine 46 09-30-2007 10:01 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 02:01 PM
