We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 09-02-2008, 04:24 PM
Ned in MO Ned in MO is offline
Century Welder Part # or size of allen screw
Assisting grandson with tools/shop left by deceased father in law. Century MIG Welder, 145 Amp, Mod # 117-069-000 is missing screw, probably allen screw to hold welding wire sheath in. Anyone with a manual to tell me what screw to obtain? I am at out of state location, working at a location disadvantage.
Old 09-02-2008, 04:26 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
OneMoreTime's barnstar
Wiki editor
Wiki Edits: 3
I y ou can find an ace hdwre store with a good nut bolt rack they should have them..might be metric so you need to check that..
Sam
I would rather make it work than make it popular..And if it does not work it will not be popular..
Old 09-02-2008, 04:40 PM
Century Welder Part
Roger, need my taps from home to discover size and thread, but I am 3 states away. I think my grandson has some contacts.
Old 09-03-2008, 08:02 AM
1ownerT's Avatar
1ownerT 1ownerT is offline
1ownerT's barnstar
Wiki editor
Last wiki edit: Building a new shop
Wiki Edits: 2
I believe that Lincoln owns Century, you may try contacting them. HERE
Old 09-03-2008, 08:12 AM
oldred oldred is offline
I am almost certain this is just a common Allen socket set screw that could easily be found at any hardware store for just a few cents.
Old 09-03-2008, 10:55 AM
Part for old Century Welder
Bingo, found a tap & die set, dug the welder out of the corner and the allen screw needed is a 10-24. Should have the welder in operation tonight. Ned in MO
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Century Welder Part # or size of allen screw"
this is a saver.... GM build codes TooMany2count General Rodding Tech 23 11-21-2008 07:27 PM
23 T Bucket ? bowtieorbust General Rodding Tech 163 02-28-2008 08:28 PM
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
Century 160 MIG Welder Phrank Garage - Tools 5 11-30-2004 05:08 PM
