Cerium Oxide on windshield - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2010, 08:07 PM
Hello
I finally decided to get the overspray off the inside of my windshield when it was in the bodyshop
I did not think it was going to be a big deal, but it was
I got most of it off, but wherever the overspray was, it has left a flat finish or almost a etched spot on the window
My car has to be ready by next wed and I do not know what to do. I have some Cerium Oxide that was given to me from a friend some time ago for a scratched window, but I never tried it yet
Any ideas? This is not a small spot on the window
thanks for any advice or info
Tom
Old 06-19-2010, 08:46 PM
BOBCRMAN@aol.com's Avatar
I have used cerium on a few old windshields. Use a fairly hard buff and keep area cool. Gives acceptable finish.
Old 06-19-2010, 09:23 PM
Hi there,
cerium oxide is used as the final polish on optical glass, camera lenses and telescopes, it is for ultra-fine polishing. it's also slightly radioactive so wear gloves and wash your hands before eating.
"I got most of it off, but wherever the overspray was, it has left a flat finish or almost a etched spot on the window"
I doubt there is any paint on the market that can etch into glass. To remove what is left try 'Mother's Mag & Aluminum polish', works very well and faster than cerium oxide.
Good luck with it.
Old 06-19-2010, 09:28 PM
TucsonJay's Avatar
Usually a razor blade and some lacquer thinner will take anything off.
Old 06-19-2010, 09:57 PM
Thanks very much for the replies. I will look for the Mothers Polish. I may be just afraid to be apply too much pressure with the 0000 steel wool
Old 06-19-2010, 10:31 PM
TucsonJay's Avatar
Do yourself a favor, and try a 25 cent single edge razor blade.
I have been painting 45 years, and done hundreds of jobs. I've used every type of paint, this has never failed, and it comes off easy. If there is a fine residue left, it should wipe off with thinner. After that you could use window cleaner.
Today people tend to overthink everything. A simple solution is usually the best. I shudder to think that the steel wool might damage the windshield, then you have a bigger problem.
Old 06-19-2010, 11:22 PM
I have tried the razor blade, but there is something left behind
It looks like the glass is etched and I have no idea why
I will look at it again tomorrow and perhaps I can get it to show up with a picture
Old 06-20-2010, 09:47 AM
TucsonJay's Avatar
If it is paint, you will need to wipe it with some thinner... or maybe acetone.
Roll the windows down so you don't get high. :-)
Old 06-20-2010, 10:05 AM
Joe G's Avatar
Registered user
Back when I worked in a bodyshop, our procedure for getting overspray off glass was similar to TucsonJay's. Use a fresh single-edge razor blade to remove as much as you can, then use a piece of #0000 steel wool to polish off any haze, then wash thoroughly with glass cleaner and newsprint.
Old 06-20-2010, 11:02 AM
Thanks Joe G and Tuscon Jay. I will try this again today...On top of what else I have to do, this is getting me depressed...but in 3 days it will be over
I was planning on leaving the windows up....a buzz may help me with my mood lol
thanks again
Tom
Old 06-20-2010, 06:14 PM
62galaxiguy's Avatar
I do what
Tucson jay does.It works every time.
Old 06-20-2010, 06:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have done this same thing on several cars and it works everytime for me.
Cole
Old 06-21-2010, 09:29 AM
I have got a lot of it off, but it is still marked. I have no idea what has happened in the bodyshop to do this. I have to get other things done on the car and will try to get back to this if I have time
Car is being picked up Thurs(trailer) and going to the track for sat
Thanks for your help
Tom
Flush fitting a windshield. Stovebolter Body - Exterior 4 05-19-2009 04:58 PM
Custom windshield??? zbhover Hotrodding Basics 8 03-15-2009 10:21 PM
1930u Windshield Frame Progress 1930u Body - Exterior 8 12-06-2008 07:14 AM
Which Butyl tape to use for 67 Impala windshield impalaalex Body - Exterior 3 08-10-2007 07:24 AM
Cutting curved windshield swoodard23 Body - Exterior 16 08-05-2005 10:27 AM
