Chain jumped 4-5 teeth ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2006, 09:55 AM
StevenC's Avatar
I picked up an engine that a guy had recently rebuilt. He could never get it to tune right etc. So I was going to build it a little differently.
I started by removing timing chain cover to find that the chain jumped 4 to 5 teeth. The dots NEVER line up. yet the engine "ran"? I did see on two pistons where valves had colided.
Is it possible for the engine toi run with that many teeth off or am i seeing things?
Old 01-28-2006, 10:08 AM
chain jumped 4-5 teeth?
my guess would be he was screwing around with the camshaft timing and thought he would advance or retard 4 or 5 teeth thinking 1 tooth was a degree. or he didn't line up the marks! well anyway you saved the motor and now time to rebuild it right!
Old 01-28-2006, 10:38 AM
powerrodsmike's Avatar
Wiki Edits: 161
One time I put the timing chain on the motor in my blazer and lined up the crank keyway (instead of the dot on the crank gear), with the timing mark on the cam gear. (no excuse) I think that puts it off by 2 or 3 teeth. Put it all together and it ran. Kind of. We had to drag it down the street with another truck to get it started. It wouldn't idle at all,(although it loped like a 10 second race car. sounded TOUGH), had about 4" of vacuum, and it wouldn't run above 3000 rpm with no load. It let so much raw gas out of the exhaust that you couldn't be within 10' of it without your eyes burning like you had been shot with tear gas. Once the idle was set up to 1200 or so it would stay running. It made NO power. I drove it down the street in 2nd gear. It wouldn't pull 3rd on level ground. Once I figured out what I'd done I pulled it apart and did it right. It has 50,000 miles on it now and runs like a champ. Guess the pistons didn't meet the valves on that one. I'm not sure that a motor would run 4 or 5 teeth off, but I would have never guessed that one would run 2 or 3 teeth off either. I would check those valves. later, mikey
BE different....ACT normal.
Old 01-28-2006, 02:11 PM
Jmark's Avatar
Originally Posted by powerrodsmike
Put it all together and it ran. Kind of. We had to drag it down the street with another truck to get it started. It wouldn't idle at all,(although it loped like a 10 second race car. sounded TOUGH), had about 4" of vacuum, and it wouldn't run above 3000 rpm with no load. It let so much raw gas out of the exhaust that you couldn't be within 10' of it without your eyes burning like you had been shot with tear gas. Once the idle was set up to 1200 or so it would stay running. It made NO power. I drove it down the street in 2nd gear. It wouldn't pull 3rd on level ground. later, mikey
Thanks for the chuckle, I needed it. Great story too.
Mark
Old 01-28-2006, 10:41 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
advanced cam makes the valve/piston clearance more critical...... the intake valve opens sooner chasing the descending piston.
Old 01-28-2006, 11:21 PM
StevenC's Avatar
What kind of symtoms should the engine exhibit if it was the case?
also is it possible the chain had jumpped that much from backfires?
Old 01-29-2006, 12:03 AM
Wiki Edits: 161
how much slack is in that chain? it won't "jump" 5 teeth unless it is waaay loose. If it was new it was assembled out of time. Backfireing wouldn't do a thing to the timing chain.
Old 01-29-2006, 11:01 AM
xntrik's Avatar
Most loose timing chains jump when the engine is turned off and makes its last rotations.
I have gotten reports from lots of people over the years that the car ran perfectly until they turned it off, then it would not run again....
I only had one do this, a new 69 Pontiac 400 with 36,000 miles on it. Plastic gear.
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 08:43 AM
overheating after installing timing chain 85 vette Engine 11 01-04-2005 09:12 PM
SBC, Holley floods, fixed, seems timing chain wrong 360Camaro Engine 2 09-01-2004 10:16 AM
timing chain tension VETTE GUY Engine 3 06-27-2003 02:15 AM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 10:22 PM
