Chain saw sharpening machines - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2008, 08:26 PM
cboy's Avatar
Last journal entry: Finished
I have tried a couple of the dremel type chain saw sharpening devices but have found them to be less than ideal. Does anyone have a good little machine to recommend for sharpening? (Not looking for "field sharpening" with a file...but rather something that will bring the teeth back to their correct angle etc. after a number of field sharpenings.)
Always learning...and sharing what I've learned.
Old 07-16-2008, 08:31 PM
wretched ratchet's Avatar
one full turn after it squeeks
a buddy of mine had one that ran off his car battery and the key was that it didn't use high rpms so therefore reduced the heat transfer considerably - - - I'll see if I can find out where and who he got it from - - - been a few years so we'll see.
Old 07-16-2008, 09:00 PM
4 Jaw Chuck's Avatar
I "field" sharpen my chain saw with a air powered die grinder with a proper size stone and then dress the depth tooth with an angle grinder equipped with a 320 sanding disc and firm rubber backer.
Don't laugh! I find I do as good a job or better than a professional jig job, it takes 10 minutes to do and once you get good at it you won't go without a sharp blade ever again.
I once did one for a friend of mine and he just about freaked when he saw how I was going to do the job when I pulled out the tools, this was his brand new Husqavarna and he had an unusual attachment to his long worn out original blade.
It took longer to get him to let me sharpen the blade than the actual sharpening but in the end even he admitted it looked and performed as good as new.
I think most people don't trust how accurately your Mark I eyeball can get an angle if all you do is move the blade to the next tooth and hand grind each gullet without moving your hand, the fact that you only spend a few seconds doing each tooth adds to the accuracy and leads to less metal removed from each individual tooth.
Once you can completely sharpen a blade in less than 10 minutes by hand you will never let a blade get dull as a touch up takes even less time. The blade lasts longer too and it won't cost anymore than a handfull of stones.
Some pointers for success;
1) Buy the white stones as they are pure alumina oxide and cut "softer" with less heat, they wear faster but also cut faster too...buy them by the bag.
2) Use a vise to hold your saw at table height, its easier to see what your doing and the rigidity of the vise makes the job easier.
3) If one tooth is badly chewed up touch it up like the last one, don't spend a bunch of time trying to fix it up and make it perfect. It will eventually get worn down like the others after a number of sharpenings.
4) Dress the top of each tooth with a fine hone to get rid of the burr, this stops "digging in" on the first cut and prevents the burr getting torn off during the first cut which will "rag" the tip causing excessive wear that you will have to grind back to during the next sharpen.
5) Keep a sponge handy to wet and cool each tooth before and after the grind, you should never grind so long that it turns blue from the heat.
6) Don't tell your friends how fast you can do it, cause it worth at least 10 bucks for 10 minutes work!
P.S. Throw away the file, they do a crappy job of sharpening a saw blade and are even harder to keep a good angle, the idea with a die grinder is light pressure which aids in the accuracy.
Old 07-16-2008, 10:37 PM
classicautoresto's Avatar
Rust Buster
Last journal entry: birthday surprise
My father just bought one from Harbor Freight that mounts to the bench and looks like a mini cut-off saw. He paid 39.99 for it, and I have to admit does a darn good job! Chain locks in and it cuts at the correct angle.
Old 07-16-2008, 11:02 PM
I got one of the HF outfits too and it works good, really good! I got mine on sale and with a one item discount coupon I had I got mine for about $28.
How do I remove the timing chain on a 350? piniongear Engine 9 09-20-2010 10:39 PM
Chain Link (No, not a fence!) BillyShope Suspension - Brakes - Steering 23 10-20-2006 03:34 PM
Chain letters powerrodsmike Off-Topic 2 06-18-2006 08:42 PM
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 09:43 AM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 11:22 PM
