Chainsaw Powered Bicycle - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 04-26-2008, 09:12 PM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Ok I have a 38cc 4.0 Horsepower Poulan WoodShark Motor that I plan on mounting to a Bicycle. I have welded a 17 tooth sprocket that runs to a 45 tooth sprocket. Do anybody think this gearing would allow the motor to move someone who weighs 180 ? What sppeds do you think it would be capable of ?. Thanks Any suggestions Appreciated.
VROOOM !!!!!!
Ok I have a 38cc 4.0 Horsepower Poulan WoodShark Motor that I plan on mounting to a Bicycle. I have welded a 17 tooth sprocket that runs to a 45 tooth sprocket. Do anybody think this gearing would allow the motor to move someone who weighs 180 ? What speeds do you think it would be capable of ?. Thanks Any suggestions Appreciated.
Old 04-26-2008, 09:33 PM
need more info please, what is the rpm specs on the motor and what size wheel?
Old 04-26-2008, 09:36 PM
VROOOM !!!!!!
Specs
4.0 Horsepower The cluth Releases at 3000 rpm the max rpm is 8 - 10000 The Wheel Size is 20 inches and the total weight is 200 pounds
Old 04-26-2008, 09:43 PM
Go to <www.motoredbikes.com>
Old 04-26-2008, 10:17 PM
It looks like your setup will pull 225mph I think your going to need to re think some gear ratios lol http://www.diygokarts.com/speed-calculator.html One thing I would consider is a rear Derailleur, maybe off a mountain bike. Depending on the Derailleur and wheel you could have a 3-9 speed chainsaw powered bike. That would be pretty sweet.
Jordon
Old 04-27-2008, 12:52 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That would be Ok for the jack shaft gearing..Look up whizzer motor bikes..Another thing that was done was to drive a small wheel attached to the jack shaft which then set on the main wheel and dove it..those bikes would get up to about 15-20mph as I recall..More of a bicycle with a motor assist for when you are tired of pedaling..The whizzer bikes had a belt driven pulley which ws nearly as big as the rear wheel..
Sam
Car Powered By Water A Reality 35WINDOW Hotrodders' Lounge 37 04-10-2009 03:09 PM
diesel powered vette 383silverado Engine 26 07-22-2007 07:08 AM
High Powered Coil's Question Francis Electrical 3 04-12-2004 04:36 AM
Mounting chainsaw engine to go-cart frame Wrench_head0944 Engine 5 07-19-2003 02:16 AM
