Chamfered bearings or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2007, 01:32 PM
Decadent pianoplayer
Ive bought a Lunati crankshaft for my CSB 350. Its an older model but in mint condition. The previous owner seems unsure if it needs chamfered bearings or not (youd think hed know...). Now Ive heard that theres a way of telling this. Can anyone tell me how please?
Old 04-29-2007, 06:12 PM
King of my Man-cave.
Compare the journal radii with a stock crank. If the Lunati crank has a noticeably bigger radius, use the chamfered bearing. Or just use the chamfered bearing regardless.
BTW, some manufacturers are eliminating the chamfer and are just making the bearing a narrrower instead; accomplishes the same purpose.
tom
Old 04-30-2007, 04:01 AM
Thanx! So I can use chamfered bearings regardless but not the other way around?
Stroker Clearance Methods and bearings ssmonty Engine 2 04-21-2007 12:36 PM
destroyed con rod bearings - pics and description - what happened ? lowROLLERchevy Engine 36 12-06-2006 09:10 AM
King Bearings good? Looking for good bearings Warrant Engine 4 06-11-2006 06:50 PM
will these bearings work? 79 Malibu327 Engine 3 01-13-2005 08:59 PM
Repacking Wheel Bearings? oldschoolrods Suspension - Brakes - Steering 5 05-10-2004 06:37 AM
