Change 1986 chevy TBI to a carburated engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2009, 12:25 PM
I have a 1986 corvette with TBI it is way to complex for me i am old school i want to change to a intake and carburated engine can this be done and what are the pitfalls if any in doing this
Old 11-24-2009, 01:40 PM
fast68's Avatar
likes chevy trucks & boobies
tbi is real basic actually
youll have to change wiring,
fuel sender unit
accel cable
the 700r4 lockup converter wont function anymore
and more issues also.,.
id leave it be if it runs fine.
hmm
tbi is easy to repair and make run great, rarely anythin goes bad other than fuel pump, EGR valve, cap rotor, or IAC needing cleaned,
im olld school learned on carbs also and have obnly owned a few tbi vehicles but now that i have had a few i love em,. run good and reliable and easy to work on,
no one is ever happy with what they have though, for some reason,.
good luck
Old 11-24-2009, 05:49 PM
OK I'm surprised, 1986 should be TPI which came on in 85 to replace the cross ram TBI? So what is it and does it have the L-98 aluminum heads?
Bogie
Old 01-07-2010, 11:22 AM
Still confussed
I have a iron head 1986 corvette,with a cranking problem,it will start right up after you get to where you are going it may or may not crank again,it will turn over just not crank if you let it sit for a while it will crank,have change on board computer, fuel pump, coil ,wires, checked fuel pump pressue fine.I have run out of options
Old 01-07-2010, 12:50 PM
Check for the engine temp sensor that goes to the computer, it's probably not working when the engine gets warm. A quick way to check is when the engine is warm and won't fire, if you shoot some starting fluid into the intake and it lights off, then that sensor is bad.
Bogie
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
Need some help with 1986 GM 305, TBI or Carbed??? dieselcruiserhead Engine 8 12-19-2010 08:32 AM
1989 S-10 4.3l TBI: engine hesitation Roddin Rob Engine 9 02-28-2006 08:11 PM
need Chevy truck engine decode info pre - 1954 khardy Engine 1 12-07-2004 07:16 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
