Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Change 4.11 to 3.08 rear end gears
Old 05-21-2006, 08:19 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by cares
I'm new to this forum. I need some help on changing out the posi 4.11
gears to 3.08 gears. The hotrod has only 450 miles on it but I don't
need the low gear ratio.
Can I do a 'straight over' exchange? without changing the axles? What
is the cost of 3.08 gears? The gears in the '32 coupe are from Randy's
Rack and Pinion Shop out of Washington state.
thanks for any assistance.
please give a clue on the make , year , model of the rear end you are working on...
or at least some more information.
