-   -   Change 4.11 to 3.08 rear end gears (http://www.hotrodders.com/forum/change-4-11-3-08-rear-end-gears-89999.html)
cares 05-21-2006 06:05 PM
I'm new to this forum. I need some help on changing out the posi 4.11
gears to 3.08 gears. The hotrod has only 450 miles on it but I don't
need the low gear ratio.
Can I do a 'straight over' exchange? without changing the axles? What
is the cost of 3.08 gears? The gears in the '32 coupe are from Randy's
Rack and Pinion Shop out of Washington state.
thanks for any assistance.
Crosley 05-21-2006 07:19 PM
please give a clue on the make , year , model of the rear end you are working on...
or at least some more information.
cares 05-22-2006 07:30 PM
I called Randy's ring and pinion today and they said with my tire size (265/70s) 0n 16 rims, I should not have a problem with 411 gears. maybe it is my tranny...
I'll start a new thread
Thanks
Tom31 08-13-2006 01:35 PM
4:11 gears
I an looking for 4:11 to put in our coupe ,we have 3:40 in it now . What size housing do you have?
cares 08-13-2006 01:46 PM
It was the transmission.... I'm keeping the 4.11's
Thanks
