Change for a 8" to a 9" rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2006, 10:21 PM
I have a 65 mustang with a 8" rear end, I would like to change it to a 9'' without the expense of a new one. Is there a donor vehicle with that will be a direct swap? Maybe one with disc brakes so i can kill to birds with one stone. Thanks
Old 09-19-2006, 10:36 PM
Jmark's Avatar
Lots of good info on that swap at the link below.
http://www.google.com/search?hl=en&q...+9%22+rear+end
Old 09-20-2006, 05:40 AM
nitro_baller4692's Avatar
floppers forever
try http://www.fordification.com/rearends-ford3.htm
they give good info
Old 09-20-2006, 08:48 AM
astroracer's Avatar
Just to satisfy my curiousity.... What is your intent with the 9"? A good rebuild on the 8" with a posi unit and gears would be easier then trying to find a 9" to fit... If it's a driver that would be my suggestion. Less of a tear up on the car also...
Mark
Old 09-20-2006, 08:55 AM
I might still just rebuild my 8" it would be alot easier.
Change 4.11 to 3.08 rear end gears cares Transmission - Rearend 4 08-13-2006 01:46 PM
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 02:22 PM
'86 El Camino Rear End Change MI2600 Transmission - Rearend 4 07-04-2004 03:58 PM
Rear End Change... Juicer Transmission - Rearend 0 10-07-2003 10:23 PM
Change gears in viper rear end fflen Transmission - Rearend 1 04-25-2003 04:40 PM
