change colors - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2009, 08:10 AM
change colors
How can I change my blue bucket seats to red or black ,are they some kind of spray I could use they are in good shape there cloth . I'm going two tone inside red and black Thank's
Old 04-20-2009, 08:42 AM
Last journal entry: 50 Ply wagon
There are spray dyes on the market that can be used. The down side of using a spray is that after extended uses, it does wear off.
Old 04-20-2009, 10:16 AM
boatbob2
vinyl spray......
HI,yes,you can buy vinyl spray in colors from NAPA,BUT,use grease and wax remover on seats at least 3 times,while wet,use a clean paper towel to remove wax and grease.as stated in above post,the color will wear off.probably in about 3 to 6 montrhs,but,its cheaper than re-upholstering,OR,go to jc whitney and buy new seatcovers.
Old 04-20-2009, 11:27 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Guys, he has CLOTH seats. You can not re-color cloth fabric seats to make a drastic color change. SEM has products to enhance the color you already have, but blue to red and black is too great a color change. If they were vinyl or leather it would be a different story.
colors for Youngrodders.com, looking for feedback Jon Hot Rod Art 29 04-20-2007 11:44 PM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
Can I change from a 28 to 26 spline carrier? artillerystevens Transmission - Rearend 0 03-05-2007 11:53 AM
Small base circle cams / pushrod length change??? hotrodf1 Engine 1 12-05-2006 10:49 AM
I want to fix and change the interior colors how do i do that? chedstar Interior 2 09-10-2003 04:17 PM
