Yes it is possible. You first should figure out what gear you have in there currently, and change accordingly. the TH350 does not have an overdrive and even if you change the rear to a relatively high gear the tranny will still be winding at a high rev at highway speed and you will sacrifice low end torque. More involved addition to changing the final drive, a gear vendor overdrive or a 700r4 or 2004r would also be a nice upgrade if you are using it mostly for a DD.
