Change gears in Ford 9 inch - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-12-2012, 05:25 PM
So ProStreet whats your recommendation and what will it set me back?
  #17 (permalink)
Old 07-12-2012, 06:53 PM
Ford Racing M-4204-F31A and a Richmond F9350.
You can get a Timken install kit from Autozone for cheap. You will have to know which carrier bearing you have, and if you have a Daytona style pinion support to get the correct kit.
The Following User Says Thank You to lmsport For This Useful Post:
stickerbush1970 (07-13-2012)
  #18 (permalink)
Old 07-12-2012, 07:02 PM
prostreet6t9's Avatar
Differential/Driveline
I'm not allowed to sell stuff here. And really to be honest I just post to try and help out. Sometimes my post's are short and to the point,but most of the time I'm at work and I do it in my spare time. I think the 325 ratio would fit your needs pretty well.
Here are some examples...
Yukon.. High performance Yukon Ring & Pinion gear set for Ford 9" in a 3.25 ratio. - YG F9-325
A cheaper set that may whine.. USA Standard Ring & Pinion gear set for Ford 9" in a 3.25 ratio - ZG F9-325
We didnt talk about spline count of your axles.. But here's a 31 spline duragrip with the aggressive set up.Yukon Trac Loc for Ford 9" wtih 31 spline axles. Aggressive Design - YDGF9-31-AG
The aggressive design is set up a little tighter and may chatter a little. I actually have great luck with them not chattering. If thats a concern you can get a "street" design unit and not worry about it.
The Following User Says Thank You to prostreet6t9 For This Useful Post:
  #19 (permalink)
Old 07-12-2012, 07:33 PM
[COLOR=#e2cc84]High performance Yukon Ring & Pinion gear set for Ford 9" in a 3.25 ratio. - YG F9-325[/COLOR]
[COLOR=#e2cc84]Yukon Trac Loc for Ford 9" wtih 31 spline axles. Aggressive Design - YDGF9-31-AG[/COLOR]
with both of these is there any thing else I need to get, shim kit like lmsport suggested. Then if the spline count is different how do I go about that. Thanks for all the info
  #20 (permalink)
Old 07-13-2012, 05:50 AM
big gear head's Avatar
High Performance Rear Ends
First off I lost my job in 09 making 45,000 a year. during those three years off I went to school and obtained a Microsoft Cerified System Engineer degree which landed me a job @ 75k a year. So yea new read end, gonna need new rubber, and go **** yourself.
What's that about?
I have the aggressive Yukon unit in mine and it doesn't chatter at all. I took a Detroit Locker out and installed the Yukon unit to test it and see if I could break it. So far it's worked great. I've got a 427, 4 speed and 15 inch wide tires and I beat on it pretty good.
The Following User Says Thank You to big gear head For This Useful Post:
  #21 (permalink)
Old 07-13-2012, 10:56 AM
Originally Posted by big gear head View Post
What's that about?
There WAS a post from DA34guy that was pretty STUPID and the OP was speaking to him. Looks like the post was removed.
  #22 (permalink)
Old 07-13-2012, 11:09 AM
OK, I missed that one. Thanks.
  #23 (permalink)
Old 07-13-2012, 11:47 AM
Atta Boy!!!!! I like your version of 'R&D'
  #24 (permalink)
Old 07-14-2012, 05:31 PM
Alright another question, what would the racing spool and the 3.73 gears be worth.
  #25 (permalink)
Old 07-14-2012, 05:41 PM
Is it a standard spool or a mini spool? I'm guessing that it's probably 31 spline. You might want to try and sell it as a complete chunk and just build yourself another complete chunk. You would probably have better luck selling it like that. You can pick up used chunks at swap meets for around $50. You are going to be replacing everything inside it anyway.
  #26 (permalink)
Old 07-14-2012, 06:07 PM
True, so I dont get screwed as the money I make off this is going towards the other rear end, whats it worth both ways.
  #27 (permalink)
Old 07-14-2012, 10:56 PM
It's hard to say what it's worth, and I don't like putting prices on other people's stuff, but I've seen rebuilt chunks with new bearings and rebuilt Trac Locks go for around $450 at swap meets. That's been a few years ago.
Can I change ford 9 inch lug pattern to match chevy 71novafreak Transmission - Rearend 7 11-06-2011 10:16 AM
Changing out Ford 9 inch Gears 31fordcoupe Transmission - Rearend 27 06-04-2011 11:20 AM
Yukon 3.75 gears for Ford 9 inch....noise 96lt4c4 Transmission - Rearend 127 04-27-2011 07:36 AM
Ford 9 inch w/ 3.50 gears kleen56 Transmission - Rearend 6 12-30-2008 10:45 AM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
