Change from HYWY gears to Drag and now have higher times than before? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-01-2012, 11:33 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
When I swapped gears I didn't notice a big improvement until I matched the converter to the the rear gear.
350 chevy sputters under load in higher gears. monzter Engine 19 08-05-2011 06:29 PM
should I change gears? cutthroatkid Transmission - Rearend 5 09-01-2009 10:37 PM
Overheated a few times now... change oil? ForceFed86 Hotrodding Basics 8 07-17-2009 03:22 PM
Change gears or trans?? Red neck blazer Transmission - Rearend 8 03-13-2008 10:38 PM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
