Change lug pattern on disk brake conversion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 11:55 AM
I am going to put front disk brakes on my 1968 chevy PU. The conversion kits come with standard 6x7/16" lugs wheels or 5x1/2" lug wheels. Is there a reason I should convert to the 5 lug pattern over the standard 6 lug pattern?
I am leaning toward staying with the 6 lug pattern as this will continue to match the rearend but is there a reason to convert to the 5 lug?
Old 01-21-2006, 12:29 PM
poncho62's Avatar
Wiki Edits: 5
Availability of custom wheels, 6 vs 5 lugs, would be a big factor. If you want to keep the stock wheels, go 6, if you want custom wheels I would go 5. If you are going to change to 5 lug on the front, get the rears redrilled, or change axles to match.
Ontario Rodders
Old 01-21-2006, 02:12 PM
re:Change lug pattern on disk brake conversion?
Thanks,
5 it is! Gonna order now.
1956 Pontiac Starchief disc brake conversion lsb Suspension - Brakes - Steering 11 02-28-2006 08:32 AM
Junk Yard Disc Brake Conversion rfowler Suspension - Brakes - Steering 14 02-17-2006 01:04 PM
C10 6 Lug to 5 Lug Conversion Quick66 Transmission - Rearend 6 12-25-2005 03:35 PM
How To change to Disk Brakes 1967 Camaro roys63 Suspension - Brakes - Steering 13 11-27-2003 10:28 AM
1946 Chevy Disk brake conversion kikazz55 Suspension - Brakes - Steering 0 04-17-2002 12:55 AM
