Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - change shafts
Thread: change shafts
Old 10-24-2012, 03:48 PM
E.Furgal E.Furgal is offline
Last journal entry: was hoping for better than this
iirc you have to change the tail shaft housing not the tail shaft..
and add the mechanical speedo gears..
not even sure you have to change the tail shaft housing, if you can find the mechanical speedo unit in another 700
