change shafts
i got to change the tail shaft on a 700r tranny one is electric the other is cable drivin how do i am putting this in a 1990 chev pick up 2 wheel drive with a 350
iirc you have to change the tail shaft housing not the tail shaft..
and add the mechanical speedo gears.. not even sure you have to change the tail shaft housing, if you can find the mechanical speedo unit in another 700 |
thank you so much for the reply, i have the old tranny will try to use that speedo in new one
If you have this on the trans now:
![]() Remove that metal disc, look for holes under the disc. You need these parts for mechanical speed-O :
At the Bonneville Salt Flats, first gear is known as 130 mph. |
yeah i got them parts but problem is how do i get that gear off of shaft can you call me 256-548-7028
Last edited by bamagirl; 10-24-2012 at 10:57 PM. Reason: had more message to add |
| cam shafts | chris robarge | Introduce Yourself | 1 | 12-08-2010 06:55 PM |
| TH350, rotation of shafts | resinlake | Transmission - Rearend | 2 | 06-23-2009 12:52 PM |
| T-5 tail shafts | bluestang67 | Transmission - Rearend | 9 | 03-22-2007 05:37 PM |
| Are all C6 output shafts 31 spline? | Rustydawg | Transmission - Rearend | 1 | 11-25-2004 09:27 PM |
