Change Wheel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2011, 11:43 PM
Change Wheel?
I have a 1973 Cadillac tilt, telescopic steering column and want to change the wheel itself. There are some after market wheels that fit the Cadillac that I have, but they lose the telescopic feature. Has anyone made a wheel to fit and still retain the tilt, telescopic? I've been told that cutting the center part of my wheel (without the spokes) and welding or bolting this to another wheel will work, but what about the lever for the telescopic feature? I would take the column out and exchange it for something else, but to remove it requires an awful lot of work, more than it's worth. I could really use help on this one.
Old 08-11-2011, 07:17 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Reread this question and realized to late he was talking about the telescope function of the column, so a correction was made.
Old 08-11-2011, 10:57 AM
evolvo's Avatar
Heathen
This is from Julianos catalog:
oops! couldn't get that to work!
Just go to Julianos website and search "tilt adaptor". This came up with 6 hole or 9 hole tilt and tele adaptors
Good Luck
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 11:05 AM
58 chevy belair 4 wheel disc brakes change over Rick England General Rodding Tech 1 02-22-2006 10:40 PM
17" Wheel Change '03 GMC 68NovaSS Suspension - Brakes - Steering 1 06-26-2003 10:48 PM
Won't change,wont' chang,won't change Samrupert Transmission - Rearend 6 01-11-2003 02:32 PM
