Changed Differential, Now How Do I Calibrate the Speedometer? '49 Ford F-1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2010, 05:35 PM
1949 Ford F-1 truck. I put a Ford 9" rear axle under it with a higher differential ratio, naturally the speedometer is way off.
Still running the stock 3 speed transmission.
I assume I need to change out the gears in the transmission that feed the speedometer. I don't have the machine tools necessary to make my own.
Is there a source for a new gear set, or what would you guys suggest?
Old 02-12-2010, 05:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depending on what tranny you're using, you can either change the speedo gears like you mentioned (HERE is the TCI calculator- they also sell the gears), or use an add-on calibration unit that mechanically alters the trans speedo output to correct for tires or gear changes.
The add-on unit attaches like your speedo cable does, to the tranny. Then the speedo cable is attached to the unit.
Sometimes the speedo head can be recalibrated.
Old 02-13-2010, 06:57 AM
When I needed to changed the speedometer calibration on my 1948 Ford ... I changed this. This bolts on to the transmission and the speedometer cable goes to it. The one in the photo is a 19 tooth A 18 tooth would speed the speedometer up. A 20 tooth would slow it down.
A 1949 Ford F1 may have a different speedometer drive setup. ( I had a 49 F-1 I installed a SBC into many years ago ,,, but it has been too long to remember ) ... but there are companies who sell a speedometer adapter ... geared to fix your problem.
I suggest you read this
http://www.speedometershop.com/ratio.html
Deuce ... Moderator
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
rear differential for 46 ford rp1 Suspension - Brakes - Steering 1 09-08-2003 07:43 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
49 Ford??? Weimer Hotrodders' Lounge 17 10-12-2002 05:19 PM
