changed from oem starter to high tork mini starter , wires .? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2010, 03:56 AM
i have a 1967 chevelle , i installed a 78 corvette steering coloum, with the switch in the coloum, i bought a mini starter but there is no pole for the s side on the right side for the wire , where does the wire go to now? thanks don
Old 09-03-2010, 05:17 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
BE helpful to know what starter you have.
If you only have the big battery cable post, then it will be necessary
to use a Ford type relay between the starter and the battery.
Cable from battery to solenoid>>>>.solenoid to starter
Purple wire from your harness to the S term on the solenoid.
Most mini starters I have seen have the "S" post already there, but a lot of them do not have the "R" post.
Those without the "R" or ignition post would need a relay to provide 12v to that post while starting-----if your car needs it (points distributor or an ignition switch that is not bussed between "RUN" and "START"
Old 09-04-2010, 05:34 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Seems that the mini-starter you have has no solenoid. Get one with the proper solenoid that the S (start) terminal and the I (ignition) terminal.
See attached.
vicrod
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
how do i wire my mini starter dennis 1966 Electrical 5 05-30-2006 05:59 PM
High torque mini starter noisey inkrat Engine 2 09-08-2005 10:44 AM
CVR Mini starter wiring Crunch01 Introduce Yourself 1 10-18-2004 06:47 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
