Changed starter now car won't start? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2008, 02:13 PM
I just changed starter on '73 Corvette 454 w/HEI and now car cranks and won't fire. Does either of the small wires have anything to do with this problem? Car started before starter change. I have power going into dist. but none at plugs but i only changed starter.
Thanks, Todd.
Old 11-26-2008, 03:05 PM
try switching the small wire to the other post on the starter. if your starter has 2 small post u might hooked that up wrong.... been there done that
Old 11-26-2008, 04:33 PM
Thanks, i tried that but no go. Traced power and it seems dist. module is done.
Old 11-26-2008, 04:51 PM
poncho62's Avatar
Wiki Edits: 5
Possible that you didn't hook up a small wire..........goes from the "S" terminal of the starter to the coil, so that you have 12 volts while cranking the engine.. See if you have 12 volts at the coil, while cranking.
Ontario Rodders
Old 11-26-2008, 05:40 PM
Checked the small wires [thanks] and even swaped them around. They were in the correct postion to start with.
With the key in the on postion the wire that goes into dist. cap/battery terminal is hot but it ends there so i'm guessing the module is bad. I have an extra so i'll try that, if not i swap out the coil with an extra. Again guessing, but it's something in dist.
head gasket replacement now car won't start jesse01 Engine 10 04-28-2007 05:53 AM
small flame comes from caburetor and car will not start Olds 69 Engine 29 11-16-2004 04:30 PM
5.0 HO, Changed plugs/wires now starter won't turn over dmc12mk3 Engine 7 06-22-2004 02:12 PM
Please help - 87 IROC Ignition replaced, car won't start dpjmw Electrical 1 01-13-2003 03:21 AM
