changing a 4 pin distribture to a 7 pin - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2004, 04:48 PM
I would like to put a Holley 950 commander on a 1975 corvette. I have a 4 pin HEI distributer. This system says it needs a 7 pin distributer do you know of any ways to converts the 4 pin to a 7 pin or how to work around this problem so i can use the EFI carb. on my car? Thanks geno
Old 01-18-2004, 05:40 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I have always gone the other way 7-pin to 4-pin, but from what i can remember everything will fit in either internally, BUT for the 7-pin to fit I think I remember there will have to be another notch cut into the side of the distributor housing for the conversion.
The internals will interchange but the extra wire harness bulkhead connector slides down into a slot that you will have to cut into the side.
In this picture, the large notch in the distributor laying with the top to the upper left side is the one that needs to be cut in.
In the lower right side view of the top of the distributor the same notch is located at about the 2: O-clock position.
Old 01-18-2004, 10:00 PM
Gino Fultano's Avatar
New Member
geno, i think you spelled your name wrong
Old 01-19-2004, 12:03 PM
what about the extra parts?
the three extra pins that are not what are they going to be used for? thanks alot.
Also do you think this cammander 950 will work good on a 383 supercharged with a whipple charger? Thanks for the advice. Geno (WITH AN E)
Old 01-19-2004, 03:52 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The extra pins and the wiring for them are for the CCC or computer command control system, or later known as the ECM, or computer for all us regular folk.
They allow the computer to see where the engine is operating in its RPM range, and to make minor adjustments according to what the computer is designed to do.
I don't forsee a problem as long as you can make adjustments to the ECM for the added displacement, and added power the chip will see and not like.
Old 01-19-2004, 04:31 PM
ECM
SO, when I hook up my laptop computer to the Holley commaner 950, My laptop acts as the ECM and that is when the extra 3 pins are used. Thanks
