changing a Aod trans. over to a c6 trans. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 04:40 PM
I took out a Aod trans. & put in a c6 trans. the flex plate bolts up but after a while I broke the studs off the c6 torque converter. all the holes lined up perfect & I assumed there was no difference between them. Is there a difference to cause this? I built a 331 stroker that I bolted this up to. (sbf)
Old 11-08-2011, 06:53 PM
Dogbreath077's Avatar
Old School Motorhead
If the holes lined up, then they shouldn't have broken because of an alignment issue. You may have over-torqued them and caused a small crack that expanded into a break, or they may have already been cracked before you purchased it. Watch the torque rating and specs of fasteners and the applications. They may seem low, but they are on the money.
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 09:45 AM
1992 gmc trans shot, will 1986 trans fit? Jamesace Transmission - Rearend 4 05-06-2010 02:42 AM
Synthetic Trans Fluid Mixed With Regular Trans Fluid smokey626 Transmission - Rearend 1 06-14-2009 01:33 PM
Changing trans fluid (conditioners) zonk Transmission - Rearend 2 07-27-2004 11:26 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
