changing brake pads
when changing brake pads on discs, how would I go about getting calipers to back off to allow new pads, would it be ok to unscew bleeder nut and press them in or that would get air into system
You can also use a syringe to remove brake fluid from the master cylinder reservoir as when you push the pistons back into the calipers, the displaced fluid will go back into the reservoir. Press the pistons back into the bores with an old brake pad and large c-clamp. Mount new pads and calipers, press the brake pedal several times to push the pistons back out and refill reservoir. |
Open the bleeder screw, and connect a vinyl tube which empties into a container, so that the dirty/old fluid will exit into the container.
You want to replace the old with the new fluid. Add new brake fluid to the master cylinder as you go. |
However if it were me, Id just pop the top to the master cylinder and use a c-clamp like was mentioned. Never had trouble with this method.
Bringing history and technology together. |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Should new brake pads rub slightly on new rotors | firewood | Suspension - Brakes - Steering | 4 | 11-25-2003 09:16 PM |
| Help!! Changing disc pads | olds37dude | Suspension - Brakes - Steering | 9 | 10-27-2003 10:53 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| brake changing | Frog120 | Suspension - Brakes - Steering | 6 | 08-21-2002 02:13 PM |
