Changing carbs..which is best - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-02-2013, 03:37 AM
Guys thank you again for your recommendations! Going 750 and RPM intake. I like the idea of the Corvette base. I like the look of cowl hoods but thats a savings later.
  #17 (permalink)
Old 05-02-2013, 03:40 AM
Also thanks for the clarification on those carb calculators.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Need a little help I.D. Some Carbs smgperformance Engine 2 04-23-2012 09:42 AM
New Carbs? JeffB Engine 7 09-30-2010 04:29 PM
carbs CHAD AZURE Engine 6 02-09-2007 03:38 PM
Changing sanding blocks, when changing grits, is this good or bad? Ripped Body - Exterior 2 02-06-2007 03:47 PM
Holley Carbs VS. Edelbrock Carbs. KeithB123 Engine 3 01-12-2004 10:42 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
